TwinTurbo.NET: Nissan 300ZX forum - so, i should tap it in as close as possible to the fan
Subject so, i should tap it in as close as possible to the fan
Posted by Bernie on July 28, 2000 at 4:08 PM
  This message has been viewed 10 times.
In Reply To Re: cool... can you give me any specifics? posted by Carl (SJ,CA) on July 28, 2000 at 09:08 AM
Message then? (i.e. after the relay?)
: There are two wires going to the fan, one is 12V power controlled by the relay and one is ground. Just run a wire from the positive side of the battery, through whatever switch/timer you want to use, and then tap it into that positive wire going to the fan.
Bernie
The heart of the Phoenix...
bhsiao@newssun.med.miami.edu
